跳转到主内容
Acer Chromebook C740-C4PE Solid State Drive Replacement
你所需要的
  1. Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: 步骤 1 中的图像 1,3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: 步骤 1 中的图像 2,3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: 步骤 1 中的图像 3,3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Solid State Drive Replacement: 步骤 2 中的图像 1,3 Acer Chromebook C740-C4PE Solid State Drive Replacement: 步骤 2 中的图像 2,3 Acer Chromebook C740-C4PE Solid State Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Solid State Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the Solid State Drive out of the connector.
结论
Sang Huynh
于03/08/17注册
252 声望
创作了2篇指南
团队
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G4
3 名成员
创作了12篇指南
一条评论
There are 2 types of SSD drives, m-SATA and M.2. Which does C740 use?
Guy Scree - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 738
