简介
This guide will demonstrate how to remove the motherboard from the Acer Chromebook C740-C4PE.
你所需要的
Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
Use the spudger or any other prying tool to pry the back plate off of the device.
Remove the 5mm screw holding the SSD in place using the Phillips #0 screwdriver.
即将完成!
结论
