跳转到主内容
Acer Chromebook C740-C4PE LCD Screen Replacement
你所需要的
  1. Acer Chromebook C740-C4PE LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Turn off the Acer Chromebook, remove it from the charger, and disconnect the battery adapter.
  2. Acer Chromebook C740-C4PE LCD Screen Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C740-C4PE LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the black frame off the screen by using a spudger.
    • It is recommended to start removing the frame from the top corner.
  3. Acer Chromebook C740-C4PE LCD Screen Replacement: 步骤 3 中的图像 1,2 Acer Chromebook C740-C4PE LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Use the spudger to open the two hinges that connect the screen frame to the bottom of the Chromebook.
    • Move the spudger along the bottom of the screen frame until you can pull the frame out entirely.
  4. Acer Chromebook C740-C4PE LCD Screen Replacement: 步骤 4 中的图像 1,2 Acer Chromebook C740-C4PE LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the four 3.4 mm screws by using the Phillips #0 screwdriver.
  5. Acer Chromebook C740-C4PE LCD Screen Replacement: 步骤 5 中的图像 1,3 Acer Chromebook C740-C4PE LCD Screen Replacement: 步骤 5 中的图像 2,3 Acer Chromebook C740-C4PE LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Place the LCD screen on top of the keyboard.
    • Lift the tape that holds the back of the LCD screen to the connector, and unplug the connector.
    • Remove the LCD screen and replace it with the new one.
结论
3等其他人完成本指南。
Sang Huynh
于03/08/17注册
252 声望
创作了2篇指南
团队
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 640
