跳转到主内容
Acer Chromebook C740-C4PE Heatsink Replacement
你所需要的
  1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: 步骤 1 中的图像 1,3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: 步骤 1 中的图像 2,3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: 步骤 1 中的图像 3,3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Heatsink Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C740-C4PE Heatsink Replacement: 步骤 2 中的图像 2,2
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Heatsink Replacement: 步骤 3 中的图像 1,2 Acer Chromebook C740-C4PE Heatsink Replacement: 步骤 3 中的图像 2,2
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Heatsink Replacement: 步骤 4 中的图像 1,1
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Heatsink Replacement: 步骤 5 中的图像 1,1
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Heatsink Replacement: 步骤 6 中的图像 1,1
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Heatsink Replacement: 步骤 7 中的图像 1,1
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
结论
另外一个人完成了本指南。
Dylan Tocci
于10/17/17注册
237 声望
创作了2篇指南
团队
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G4
3 名成员
创作了12篇指南
一条评论
What type of thermal paste is best used?
Tracey Arria - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 352
