跳转到主内容
Acer Chromebook C740-C4PE Battery Replacement
你所需要的
  1. Acer Chromebook C740-C4PE Battery Replacement, Battery: 步骤 1 中的图像 1,3 Acer Chromebook C740-C4PE Battery Replacement, Battery: 步骤 1 中的图像 2,3 Acer Chromebook C740-C4PE Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Battery Replacement: 步骤 2 中的图像 1,1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Battery Replacement: 步骤 3 中的图像 1,1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Battery Replacement: 步骤 4 中的图像 1,3 Acer Chromebook C740-C4PE Battery Replacement: 步骤 4 中的图像 2,3 Acer Chromebook C740-C4PE Battery Replacement: 步骤 4 中的图像 3,3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
结论
3等其他人完成本指南。
Jacob Kahn
于10/17/17注册
273 声望
创作了2篇指南
团队
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 499
