跳转到主内容
Acer Chromebook C740 Trackpad Replacement
你所需要的
  1. Acer Chromebook C740 Trackpad Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Trackpad Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C740 Trackpad Replacement: 步骤 2 中的图像 2,2
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Trackpad Replacement: 步骤 3 中的图像 1,3 Acer Chromebook C740 Trackpad Replacement: 步骤 3 中的图像 2,3 Acer Chromebook C740 Trackpad Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Trackpad Replacement, Battery: 步骤 4 中的图像 1,3 Acer Chromebook C740 Trackpad Replacement, Battery: 步骤 4 中的图像 2,3 Acer Chromebook C740 Trackpad Replacement, Battery: 步骤 4 中的图像 3,3
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  5. Acer Chromebook C740 Trackpad Replacement: 步骤 5 中的图像 1,2 Acer Chromebook C740 Trackpad Replacement: 步骤 5 中的图像 2,2
    • Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
  6. Acer Chromebook C740 Trackpad Replacement: 步骤 6 中的图像 1,1
    • Lift the battery from the frame.
  7. Acer Chromebook C740 Trackpad Replacement, Trackpad: 步骤 7 中的图像 1,3 Acer Chromebook C740 Trackpad Replacement, Trackpad: 步骤 7 中的图像 2,3 Acer Chromebook C740 Trackpad Replacement, Trackpad: 步骤 7 中的图像 3,3
    • Pull the black wire out from under the the black center clips and up from the gray outer clips with a spudger.
  8. Acer Chromebook C740 Trackpad Replacement: 步骤 8 中的图像 1,2 Acer Chromebook C740 Trackpad Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to lift the black clip on the small purple ribbon cable connector to the left of the touchpad.
    • Pull the ribbon cable out from the connector.
  9. Acer Chromebook C740 Trackpad Replacement: 步骤 9 中的图像 1,2 Acer Chromebook C740 Trackpad Replacement: 步骤 9 中的图像 2,2
    • Remove the five 2.5 mm screws with a Phillips #0 screwdriver.
  10. Acer Chromebook C740 Trackpad Replacement: 步骤 10 中的图像 1,2 Acer Chromebook C740 Trackpad Replacement: 步骤 10 中的图像 2,2
    • Remove the four 2.8 mm screws with a Phillips #00 screwdriver.
  11. Acer Chromebook C740 Trackpad Replacement: 步骤 11 中的图像 1,2 Acer Chromebook C740 Trackpad Replacement: 步骤 11 中的图像 2,2
    • Wiggle off the silver bracket with your fingers.
  12. Acer Chromebook C740 Trackpad Replacement: 步骤 12 中的图像 1,2 Acer Chromebook C740 Trackpad Replacement: 步骤 12 中的图像 2,2
    • Remove the black tape on the left side of the touchpad.
  13. Acer Chromebook C740 Trackpad Replacement: 步骤 13 中的图像 1,2 Acer Chromebook C740 Trackpad Replacement: 步骤 13 中的图像 2,2
    • Lift off the black plastic cover with the plastic opening tool.
结论
6等其他人完成本指南。
Flor De La Rosa
于04/25/17注册
875 声望
创作了4篇指南
团队
Cal Poly, Team S22-G2, Livingston Spring 2017 Cal Poly, Team S22-G2, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 2,553
