跳转到主内容
Acer Chromebook C732 Screen Replacement
你所需要的
  1. Acer Chromebook C732 Screen Replacement, Safety First: 步骤 1 中的图像 1,1
    • Make sure your device is turned off and disconnect your battery from the motherboard.
    • You can find a detailed guide for getting to and replacing this device's battery here
  2. Acer Chromebook C732 Screen Replacement: 步骤 2 中的图像 1,1
    • Open the Chromebook so the display is facing towards you.
  3. Acer Chromebook C732 Screen Replacement: 步骤 3 中的图像 1,2 Acer Chromebook C732 Screen Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool or a spudger, carefully pry the plastic bezel around the screen.
    • If you start in the corner, you should be able to release the tabs there. Once those tabs have been released, you can release the rest by hand.
  4. Acer Chromebook C732 Screen Replacement: 步骤 4 中的图像 1,3 Acer Chromebook C732 Screen Replacement: 步骤 4 中的图像 2,3 Acer Chromebook C732 Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the four screws holding the display in place with a Phillips #1 screwdriver.
    • Carefully lower the display to rest on the keyboard.
  5. Acer Chromebook C732 Screen Replacement: 步骤 5 中的图像 1,3 Acer Chromebook C732 Screen Replacement: 步骤 5 中的图像 2,3 Acer Chromebook C732 Screen Replacement: 步骤 5 中的图像 3,3
    • The display connector is located on the back and is covered by some adhesive tape.
    • Carefully peal the tape back
    • Once the tape is peeled back, you can lift the bar to disconnect the display cable.
结论
另外一个人完成了本指南。
Jacob Mehnert
于10/18/21注册
23,806 声望
创作了42篇指南
团队
iFanatics iFanatics 的会员
Community
54 名成员
创作了141篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 422
