跳转到主内容
Acer Chromebook C731-C8VE Trackpad Replacement
你所需要的
  1. Acer Chromebook C731-C8VE Trackpad Replacement, Trackpad: 步骤 1 中的图像 1,1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 2 中的图像 1,1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and must be placed in these specific areas.
    • The 2 mm screws marked orange do not have washers attached and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 3 中的图像 1,3 Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 3 中的图像 2,3 Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 3 中的图像 3,3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 4 中的图像 1,3 Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 4 中的图像 2,3 Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 4 中的图像 3,3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 5 中的图像 1,2 Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 5 中的图像 2,2
    • Use the JIS #00 screwdriver to remove four 1mm screws that connect the trackpad to the device.
  6. Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 6 中的图像 1,2 Acer Chromebook C731-C8VE Trackpad Replacement: 步骤 6 中的图像 2,2
    • Do this step slowly to ensure that you do not damage the trackpad or the device.
    • Remove the trackpad from the base of the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 202
