跳转到主内容
Acer Chromebook C731-C8VE Keyboard Replacement
你所需要的
  1. Acer Chromebook C731-C8VE Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 2 中的图像 1,1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 3 中的图像 1,2 Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 3 中的图像 2,2
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 4 中的图像 1,3 Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 4 中的图像 2,3 Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 4 中的图像 3,3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 5 中的图像 1,3 Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 5 中的图像 2,3 Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 5 中的图像 3,3
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 6 中的图像 1,1
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
  7. Acer Chromebook C731-C8VE Keyboard Replacement, Keyboard: 步骤 7 中的图像 1,1
    • Use the JIS #00 Screwdriver to remove the four 0.5 mm screws holding the trackpad in order to detach it from the keyboard.
  8. Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 8 中的图像 1,2 Acer Chromebook C731-C8VE Keyboard Replacement: 步骤 8 中的图像 2,2
    • Lift and remove the trackpad to isolate the keyboard.
结论
Sophia Medley
于02/21/23注册
85 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 126
