跳转到主内容
Acer Chromebook C720-2848 Trackpad Replacement
你所需要的
  1. Acer Chromebook C720-2848 Trackpad Replacement, Back Cover: 步骤 1 中的图像 1,2 Acer Chromebook C720-2848 Trackpad Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Acer Chromebook C720-2848 Trackpad Replacement: 步骤 2 中的图像 1,3 Acer Chromebook C720-2848 Trackpad Replacement: 步骤 2 中的图像 2,3 Acer Chromebook C720-2848 Trackpad Replacement: 步骤 2 中的图像 3,3
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Acer Chromebook C720-2848 Trackpad Replacement, Battery: 步骤 3 中的图像 1,3 Acer Chromebook C720-2848 Trackpad Replacement, Battery: 步骤 3 中的图像 2,3 Acer Chromebook C720-2848 Trackpad Replacement, Battery: 步骤 3 中的图像 3,3
    • Unscrew the 2 battery screws.
    • Make sure you keep these screws separate from the back cover screws; they are different!
  4. Acer Chromebook C720-2848 Trackpad Replacement: 步骤 4 中的图像 1,2 Acer Chromebook C720-2848 Trackpad Replacement: 步骤 4 中的图像 2,2
    • Use two fingers to unplug the battery-to-motherboard connection.
  5. Acer Chromebook C720-2848 Trackpad Replacement: 步骤 5 中的图像 1,1
    • Take out battery by lifting it up in the manner pictured.
  6. Acer Chromebook C720-2848 Trackpad Replacement, Trackpad: 步骤 6 中的图像 1,2 Acer Chromebook C720-2848 Trackpad Replacement, Trackpad: 步骤 6 中的图像 2,2
    • Remove 9 trackpad screws. They will be of two different varieties.
    • Make sure to keep these screw separate from those in the previous steps.
    • On the back of the trackpad, there is a plastic film that will cover some of the screws. Simply pull it back (do not pull if off) to remove the screws.
  7. Acer Chromebook C720-2848 Trackpad Replacement: 步骤 7 中的图像 1,2 Acer Chromebook C720-2848 Trackpad Replacement: 步骤 7 中的图像 2,2
    • Remove the trackpad ribbon cable.
    • To do this, lift the small black component; it is hinged to the white component.
    • Then simply pull the ribbon cable out of the connector.
  8. Acer Chromebook C720-2848 Trackpad Replacement: 步骤 8 中的图像 1,3 Acer Chromebook C720-2848 Trackpad Replacement: 步骤 8 中的图像 2,3 Acer Chromebook C720-2848 Trackpad Replacement: 步骤 8 中的图像 3,3
    • Remove the small metal frame by simply lifting it out.
    • Carefully peel up the tape holding the trackpad in place.
    • Remove the trackpad from the computer frame.
    • Make sure to watch for any wires or other components and ensure that they are out of the way when removing the trackpad.
结论
Richard Schmidt
于03/19/18注册
337 声望
创作了2篇指南
团队
Baylor, Team S3-G1, Williams Spring 2018 Baylor, Team S3-G1, Williams Spring 2018 的会员
BU-WILLIAMS-S18S3G1
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 597
