简介
Use this guide to replace the battery in your device.
你所需要的
10等其他人完成本指南。
3条评论
How do you know if the battery needs to be replaced
You will know if the battery needs to be replaced if your chromebook goes dead rather quickly than it used to or if you open it up and see that your bettery is bulged or appears to be inflated then if will also need to be replaced. I hope this helps.
My Acer C720 Chromebook battery only charges to about 30-40% percent no matter how long I leave it on charger. Sometimes (randomly) it doesn’t charge at all. How do I diagnose whether I need to replace the charging port, the charging cord or the battery?
