跳转到主内容
Acer Chromebook C720-2848 Screen Replacement
你所需要的
  1. Acer Chromebook C720-2848  Screen Replacement, Screen: 步骤 1 中的图像 1,2 Acer Chromebook C720-2848  Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Insert a metal spudger around the inner side of the screens plastic perimeter.
    • Move along the perimeter while leveraging to pop the faceplate out like so.
  2. Acer Chromebook C720-2848  Screen Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C720-2848  Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the faceplate's bottom hinges that connect to the body of the device with the metal spudger. This will free the plastic perimeter, which may now be removed.
  3. Acer Chromebook C720-2848  Screen Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the 6 screws in these circled locations.
  4. Acer Chromebook C720-2848  Screen Replacement: 步骤 4 中的图像 1,1
    • Reposition so the screen will lay flat on the keyboard of the laptop.
  5. Acer Chromebook C720-2848  Screen Replacement: 步骤 5 中的图像 1,2 Acer Chromebook C720-2848  Screen Replacement: 步骤 5 中的图像 2,2
    • Locate the bar code adhesion strip at the base of the screen, and then peel it back carefully. Once peeled back the plug-in will come free.
结论
4等其他人完成本指南。
Cory Provost
于09/27/17注册
212 声望
撰写一个指南
团队
USF Tampa, Team S9-G3, Remmell Fall 2017 USF Tampa, Team S9-G3, Remmell Fall 2017 的会员
USFT-REMMELL-F17S9G3
4 名成员
创作了9篇指南
一条评论
In step 2, "the faceplate's bottom hinges" are plastic hinge covers that are (or, at least, were) part of the bezel. You may be able to take the bezel off while they're still attached, or you may have to break the flexing points so that they come off separately. Either way, it doesn't seem to cause a problem.
Thanks, Cory.
Lance ==)--------------
Lance - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 19
总计 1,761
