跳转到主内容
Acer Chromebook C720-2844 Battery Replacement
你所需要的
  1. Acer Chromebook C720-2844 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Acer Chromebook C720-2844 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Acer Chromebook C720-2844 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip to the back cover of the laptop.
    • Remove the 1 cm Phillips #00 screws on the back cover.
    • Use pry tools to remove the back cover.
  2. Acer Chromebook C720-2844 Battery Replacement: 步骤 2 中的图像 1,1
    • Take out your Phillips #00 screwdriver.
    • Remove the 1 cm screws of the battery. There are two of screws, one is on the left of the battery and the other is on the right. (circled in red).
  3. Acer Chromebook C720-2844 Battery Replacement: 步骤 3 中的图像 1,2 Acer Chromebook C720-2844 Battery Replacement: 步骤 3 中的图像 2,2
    • Unplug the battery from the motherboard by pulling the bundled cable connector free.
    • Lift the top part of battery.
    • Slide the battery forward to remove it completely from the motherboard.
结论
Fabian Sanchez
于02/10/22注册
247 声望
撰写一个指南
团队
Gateway, Team 1-2, Pee Spring 2022 Gateway, Team 1-2, Pee Spring 2022 的会员
GCC-PEE-S22S1G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 194
