简介
Use this guide to replace the trackpad on your Acer Chromebook C720-2827. This guide may also be useful for cleaning or readjusting a trackpad that is semi-functional. It will require opening the device and removal of the battery. A plastic cover sits atop the trackpad joined by adhesive, so some light adhesive may be desired for reassembly.
你所需要的
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Using a spudger, pry up the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
另外一个人完成了本指南。
