跳转到主内容
Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement
你所需要的
  1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: 步骤 1 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: 步骤 1 中的图像 2,2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 2 中的图像 2,2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 4 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 4 中的图像 2,2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 5 中的图像 1,1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: 步骤 6 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: 步骤 6 中的图像 2,2
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 7 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 7 中的图像 2,2
    • Carefully pull out the speakers from each side of the Chromebook.
  8. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: 步骤 8 中的图像 1,3 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: 步骤 8 中的图像 2,3 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: 步骤 8 中的图像 3,3
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  9. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 9 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 9 中的图像 2,2
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  10. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 10 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 10 中的图像 2,2
    • Pull the blue tab on the ribbon cable to remove it.
  11. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 11 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 11 中的图像 2,2
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  12. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 12 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 12 中的图像 2,2
    • Position the spudger under the switch.
  13. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 13 中的图像 1,2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 步骤 13 中的图像 2,2
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
结论
另外一个人完成了本指南。
Jason Bechtold
于10/19/17注册
611 声望
创作了5篇指南
团队
UMass Dartmouth, Team S4-G7, Julie Fall 2017 UMass Dartmouth, Team S4-G7, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G7
1 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 325
