简介
This guide explains how to remove the battery. Before removing the battery, the front panel assembly will also need to be removed. Once the battery is reached, you will need to unplug some cables and unscrew some screws.
你所需要的
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
即将完成!
结论
3等其他人完成本指南。
