跳转到主内容
Acer Chromebook C720-2420 Motherboard Replacement
你所需要的
  1. Acer Chromebook C720-2420 Motherboard Replacement, Back Cover Replacement: 步骤 1 中的图像 1,2 Acer Chromebook C720-2420 Motherboard Replacement, Back Cover Replacement: 步骤 1 中的图像 2,2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Motherboard Replacement, Battery: 步骤 3 中的图像 1,2 Acer Chromebook C720-2420 Motherboard Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 4 中的图像 1,2 Acer Chromebook C720-2420 Motherboard Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the battery.
  6. Acer Chromebook C720-2420 Motherboard Replacement, cooling fan / CPU heat sink assembly: 步骤 6 中的图像 1,2 Acer Chromebook C720-2420 Motherboard Replacement, cooling fan / CPU heat sink assembly: 步骤 6 中的图像 2,2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 7 中的图像 1,3 Acer Chromebook C720-2420 Motherboard Replacement: 步骤 7 中的图像 2,3 Acer Chromebook C720-2420 Motherboard Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
  8. Acer Chromebook C720-2420 Motherboard Replacement, Memory: 步骤 8 中的图像 1,2 Acer Chromebook C720-2420 Motherboard Replacement, Memory: 步骤 8 中的图像 2,2
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
  9. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 9 中的图像 1,2 Acer Chromebook C720-2420 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Pull out the SSD.
  10. Acer Chromebook C720-2420 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Disconnect the speaker cable from the motherboard.
  11. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Disconnect the display cable from the motherboard.
  12. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Gently pull out the wire for the 2 PIC connectors.
  13. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the two 3.7 mm Phillips screws that hold the motherboard in place.
  14. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Lift up the black tab on the ZIF connector to release the ribbon cable.
    • Carefully remove the ribbon cable.
  15. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Gently remove the ribbon cable
  16. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Remove the ribbon cable.
  17. Acer Chromebook C720-2420 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Lift up and remove the motherboard.
结论
Josue Pardo
于02/12/18注册
187 声望
撰写一个指南
团队
USF Tampa, Team S15-G4, Boczar Spring 2018 USF Tampa, Team S15-G4, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 316
