跳转到主内容
Acer Chromebook C720-2420 Battery Replacement
你所需要的
  1. Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: 步骤 1 中的图像 1,2 Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: 步骤 1 中的图像 2,2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Battery Replacement, Battery: 步骤 3 中的图像 1,2 Acer Chromebook C720-2420 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Battery Replacement: 步骤 4 中的图像 1,2 Acer Chromebook C720-2420 Battery Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer Chromebook C720-2420 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery.
结论
团队
USF Tampa, Team S15-G4, Boczar Spring 2018 USF Tampa, Team S15-G4, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 15
总计 555
