跳转到主内容
Acer Chromebook C720-2103 Solid State Drive Replacement
你所需要的
  1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: 步骤 1 中的图像 1,2 Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Solid State Drive Replacement: 步骤 2 中的图像 1,1
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Solid State Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Solid State Drive Replacement: 步骤 4 中的图像 1,2 Acer Chromebook C720-2103 Solid State Drive Replacement: 步骤 4 中的图像 2,2
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Solid State Drive Replacement: 步骤 5 中的图像 1,2 Acer Chromebook C720-2103 Solid State Drive Replacement: 步骤 5 中的图像 2,2
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Solid State Drive Replacement, Solid State Drive: 步骤 6 中的图像 1,1
    • Remove one 6mm screw using a Phillips #0 screwdriver.
  7. Acer Chromebook C720-2103 Solid State Drive Replacement: 步骤 7 中的图像 1,3 Acer Chromebook C720-2103 Solid State Drive Replacement: 步骤 7 中的图像 2,3 Acer Chromebook C720-2103 Solid State Drive Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
结论
2等其他人完成本指南。
Matthew Holt
于10/17/17注册
633 声望
创作了5篇指南
团队
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 UMass Dartmouth, Team S66-G3, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S66G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 299
