跳转到主内容
Acer Chromebook C720 Solid State Drive (SSD) Replacement
你所需要的
  1. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): 步骤 1 中的图像 1,3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): 步骤 1 中的图像 2,3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): 步骤 1 中的图像 3,3
    • WARNING: Make sure your device is turned off before proceeding. If you proceed with the device on, the device may be damaged
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Using the blue plastic case opener, unlatch the back of the case to expose the motherboard and other components.
  2. Acer Chromebook C720 Solid State Drive (SSD) Replacement: 步骤 2 中的图像 1,3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: 步骤 2 中的图像 2,3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: 步骤 2 中的图像 3,3
    • Remove the single 3mm screw holding the SSD with the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Solid State Drive (SSD) Replacement: 步骤 3 中的图像 1,2 Acer Chromebook C720 Solid State Drive (SSD) Replacement: 步骤 3 中的图像 2,2
    • Gently remove the SSD from the motherboard.
结论
5等其他人完成本指南。
Benjamin Rahman
于04/01/19注册
517 声望
创作了3篇指南
团队
IUPUI, Team S2-G5, Harley Spring 2019 IUPUI, Team S2-G5, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S2G5
4 名成员
创作了7篇指南
一条评论
When you’re looking for a replacement drive, its socket is for a B-keyed m.2 2242 (22m x 42m). I haven’t actually found any just-B-keyed on the market, so you’ll probably end up getting B+M keyed (like the stock drive).
Another guide which goes further into recovering the OS to the new drive is here: https://www.androidcentral.com/how-upgra...
Matt Beary - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 147
总计 4,802
