跳转到主内容
Acer Chromebook C720 Heat Sink and Cooling Fan Replacement
你所需要的
  1. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: 步骤 1 中的图像 1,3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: 步骤 1 中的图像 2,3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: 步骤 1 中的图像 3,3
    • Operating on your device while it is on, or plugged in may result in electrical shock. Make sure the device is not powered before continuing.
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
  2. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 步骤 2 中的图像 2,2
    • Remove the four 3mm screws securing the heat sink using the Phillips #0 screwdriver.
    • Remove the two 3mm screws securing the fan using the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 步骤 3 中的图像 1,2 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 步骤 3 中的图像 2,2
    • Gently pry the fan module away from the motherboard. After a bit of force, it should pop out of its slot.
    • Carefully unwrap the wires from around the fan.
  4. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 步骤 4 中的图像 1,3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 步骤 4 中的图像 2,3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 步骤 4 中的图像 3,3
    • Gently disconnect the fan module from the motherboard.
结论
2等其他人完成本指南。
Benjamin Rahman
于04/01/19注册
517 声望
创作了3篇指南
团队
IUPUI, Team S2-G5, Harley Spring 2019 IUPUI, Team S2-G5, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S2G5
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 540
