跳转到主内容
Acer Chromebook C710-2847 Wireless Card Replacement
你所需要的
  1. Acer Chromebook C710-2847 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,2 Acer Chromebook C710-2847 Wireless Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Wireless Card Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C710-2847 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Wireless Card Replacement, Acer Chromebook C710-2847 Back Cover Replacement: 步骤 3 中的图像 1,1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Wireless Card Replacement: 步骤 4 中的图像 1,2 Acer Chromebook C710-2847 Wireless Card Replacement: 步骤 4 中的图像 2,2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: 步骤 5 中的图像 1,3 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: 步骤 5 中的图像 2,3 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: 步骤 5 中的图像 3,3
    • Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
  6. Acer Chromebook C710-2847 Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
  7. Acer Chromebook C710-2847 Wireless Card Replacement: 步骤 7 中的图像 1,2 Acer Chromebook C710-2847 Wireless Card Replacement: 步骤 7 中的图像 2,2
    • The wireless card will spring up.
    • Pull the wireless card up and out to remove it.
结论
2等其他人完成本指南。
Bradley Pavy
于09/30/13注册
1,257 声望
创作了6篇指南
团队
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G3
5 名成员
创作了14篇指南
1指南评论
If you replace the original wifi card, how do you get Chrome OS to recognize, or find and download driver for Intel AC 7260 wifi card?
Thanks.
When Ze - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 6,136
