跳转到主内容
Acer Chromebook C710-2847 Cooling Fan Replacement
你所需要的
  1. Acer Chromebook C710-2847 Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 2 中的图像 2,2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Cooling Fan Replacement, Acer Chromebook C710-2847 Back Cover Replacement: 步骤 3 中的图像 1,1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 4 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 4 中的图像 2,2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710-2847 Cooling Fan Replacement, Hard Drive: 步骤 5 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • The hard drive assembly is attached to the laptop by a ribbon cable. Only lift the side of the drive facing you about an inch above the laptop. If you tear the ribbon cable the laptop will need to be serviced by a professional.
    • Use one finger to lift up the hard drive assembly from the bottom left corner.
  6. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 6 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 6 中的图像 2,2
    • Hold the hard drive assembly keeping the end closest to you near the laptop. It's ok to tilt the far end of the drive up towards you.
    • Unscrew the two silver #0 3mm Phillips screws on the left and right sides of the hard drive.
  7. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 7 中的图像 1,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 7 中的图像 2,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 7 中的图像 3,3
    • Hold the base of the hard drive in your right hand.
    • Use your left hand to pull the hard drive away from its housing. Don't let the housing tug on the ribbon cable.
  8. Acer Chromebook C710-2847 Cooling Fan Replacement, RAM: 步骤 8 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement, RAM: 步骤 8 中的图像 2,2
    • Pull the metal tabs sideways away from the memory stick.
    • The RAM stick will pop up.
  9. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 9 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 9 中的图像 2,2
    • Pull the RAM stick up and away from the laptop.
  10. Acer Chromebook C710-2847 Cooling Fan Replacement, Wireless Card: 步骤 10 中的图像 1,3 Acer Chromebook C710-2847 Cooling Fan Replacement, Wireless Card: 步骤 10 中的图像 2,3 Acer Chromebook C710-2847 Cooling Fan Replacement, Wireless Card: 步骤 10 中的图像 3,3
    • Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
  11. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 11 中的图像 1,1
    • Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
  12. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 12 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 12 中的图像 2,2
    • The wireless card will spring up.
    • Pull the wireless card up and out to remove it.
  13. Acer Chromebook C710-2847 Cooling Fan Replacement, Cooling Fan: 步骤 13 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement, Cooling Fan: 步骤 13 中的图像 2,2
    • Remove the SD card or placeholder by pressing the card in until it clicks and pops out.
    • Pull the card out.
    • Remove the screws.
    • Sixteen #0 6mm Phillips screws
    • One #0 3mm screw
  14. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 14 中的图像 1,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 14 中的图像 2,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 14 中的图像 3,3
    • Unplug the fan power cable by pulling the cable towards you using a spudger to help pop off the connection.
  15. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 15 中的图像 1,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 15 中的图像 2,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 15 中的图像 3,3
    • Unplug the cable below the lower RAM slot by using the spudger to slide the two brown clips towards you.
    • Gently pull the cable towards you using the clear plastic tab.
  16. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 16 中的图像 1,2 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 16 中的图像 2,2
    • Unclip the bottom half of the case from the laptop by using a spudger and starting at the USB port on the right side of the laptop. Then work your way clockwise around the laptop.
  17. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 17 中的图像 1,1
    • Open the laptop hinge about 45 degrees.
    • Lowering the keyboard assembly too far will damage the keyboard ribbon cable. Do not let the cable stretch.
    • Lower the keyboard assembly halfway between the case and the screen.
  18. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 18 中的图像 1,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 18 中的图像 2,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 18 中的图像 3,3
    • Push down on the black tabs with a spudger to free the ribbon cable from the case.
    • Gently pull the ribbon cable out of its slot.
  19. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 19 中的图像 1,1
    • Lower the keyboard assembly towards the screen until the clips near the hinges detach.
    • Set the keyboard assembly aside.
  20. Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 20 中的图像 1,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 20 中的图像 2,3 Acer Chromebook C710-2847 Cooling Fan Replacement: 步骤 20 中的图像 3,3
    • Open the hinge to about 90 degrees.
    • Lift up the left edge of the tape holding the fan on the right side of the motherboard.
    • Push the fan out of the back of the laptop.
结论
6等其他人完成本指南。
Bradley Pavy
于09/30/13注册
1,257 声望
创作了6篇指南
团队
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G3
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 6,266
