跳转到主内容
Acer Chromebook C710-2847 Battery Replacement
你所需要的
  1. Acer Chromebook C710-2847 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Acer Chromebook C710-2847 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Battery Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C710-2847 Battery Replacement: 步骤 2 中的图像 2,2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
结论
16等其他人完成本指南。
Adam Whitmarsh
于09/30/13注册
1,059 声望
撰写一个指南
团队
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G3
5 名成员
创作了14篇指南
6条评论
I actually used a ball point pin instead of a spudger (its dark, I'm female and I am not walking to Office Max in this neighborhood by myself). And voici, the battery came off. Now to see if the damned computer will reboot.
Daphne Macklin - 回复
I have a C710-2856, which uses a 14.8V battery. All of the extended batteries say they won't work on the 14.8V battery .Does anyone know of an extended battery that WOULD work with the 14.8V version of this Chromebook. I can up the RAM to 16GB, and I can put any SSD, but the only weakness left is the short battery life.
Tom Dison - 回复
I wish I had an answer for you! I'm looking into the same thing. All the extended batteries are 11.1 v and not compatible with the 14.8 v need of the C710-2856. Did you ever get an answer to this? perhaps elsewhere? Thanks!
Cornell Gunter -
i have a C710-2815? what kind of battery do i need for a replacement
sudanna soetome - 回复
It is a sad state of things when being female makes you unsafe. On the other hand, you won't have the American Dream drafted away from you.
xcoconino9 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 30,577
