跳转到主内容
Acer Chromebook C710-2833 Fan Replacement
你所需要的
  1. Acer Chromebook C710-2833 Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Fan Replacement: 步骤 2 中的图像 1,2 Acer Chromebook C710-2833 Fan Replacement: 步骤 2 中的图像 2,2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Fan Replacement: 步骤 3 中的图像 1,2 Acer Chromebook C710-2833 Fan Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Fan Replacement: 步骤 4 中的图像 1,2 Acer Chromebook C710-2833 Fan Replacement: 步骤 4 中的图像 2,2
    • Locate the two 6 mm Phillips #00 screws on the fan port.
    • Unscrew the two screws and place them aside for now.
  5. Acer Chromebook C710-2833 Fan Replacement: 步骤 5 中的图像 1,2 Acer Chromebook C710-2833 Fan Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the fan from its port. You may need to use a little force as there will be an adhesive on the right side of the fan keeping it in place.
    • Locate the Molex cable connecting the fan to its port in the top left corner.
    • Disconnect the cable.
结论
另外一个人完成了本指南。
Nicholas Latorre
于09/28/17注册
558 声望
创作了5篇指南
团队
USF Tampa, Team S1-G6, Nance Fall 2017 USF Tampa, Team S1-G6, Nance Fall 2017 的会员
USFT-NANCE-F17S1G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 895
