简介
If your screen breaks or has dead pixels, the most cost effective solution is to replace the screen.
  1. Place the laptop on a flat surface with the bottom side facing up. Place the tip of a spudger or finger into the hole on the battery release slider.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Use the spudger to move the slider to the right and hold it there. With the slider held, use your other hand to pull the battery back away from the laptop.
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Open the laptop, keeping the screen on the table. CAUTION: Only use the spudger on the outside of the device. Don't insert it where the bezel meets the screen Use a spudger to unclip the top left and right sides of the bezel. You should feel and hear the clips releasing as you do this.
    • Open the laptop, keeping the screen on the table.
    • CAUTION: Only use the spudger on the outside of the device. Don't insert it where the bezel meets the screen
    • Use a spudger to unclip the top left and right sides of the bezel. You should feel and hear the clips releasing as you do this.
    • Turn the device around 180 degrees, keeping the screen on the table. Use the spudger on the bottom of the screen to unclip the bezel between the hinges.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Lift the bezel one inch off the top corners of the screen. Gently pull the plastic bezel toward you.
    • Lift the bezel one inch off the top corners of the screen.
    • Gently pull the plastic bezel toward you.
    • Set the bezel aside.
  6. Unscrew the four black #0 3mm Phillips screws holding down the screen. Lift up the small pieces of black tape at the bottom center of the screen near the keyboard.
    • Unscrew the four black #0 3mm Phillips screws holding down the screen.
    • Lift up the small pieces of black tape at the bottom center of the screen near the keyboard.
  7. Lift up the screen from the silver tabs at the top and flip it over to rest on top of the keyboard. Carefully unwrap the narrow black tape from around the ribbon cable connection. Pull off the clear tape from the ribbon cable connection.
    • Lift up the screen from the silver tabs at the top and flip it over to rest on top of the keyboard.
    • Carefully unwrap the narrow black tape from around the ribbon cable connection.
    • Pull off the clear tape from the ribbon cable connection.
  8. Pull out the ribbon cable. Remove any remaining tape holding the screen to the laptop. Remove any remaining tape holding the screen to the laptop.
    • Pull out the ribbon cable.
    • Remove any remaining tape holding the screen to the laptop.
结论
To reassemble your device, follow these instructions in reverse order. Be sure to tape the cable back to the screen to avoid display problems.
30等其他人完成本指南。
Bradley Pavy
于2013年09月30日注册
1,116 信誉积分
创作了6篇指南
团队
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G3
5 名成员
创作了7篇指南
I am 69 years old and bought myself and 4 grandchildren Acer Chromebooks. I heard the screen messing up was quite common. So when my screen went first, I knew I had to learn to fix it, or spend another small fortune if they all broke down. So here I am. The screen is out..next adventure..putting a new one in. Will return here to do that. Thanks for the site.
Patricia Hadley - 回复
Worked perfectly. Replaced my daughters screen in about 15 minutes. Thank you.
Liam - 回复
Great guide. Didn't realize it was that simple...i'd like a little information on which screen was purchased for this model.
Thanks!
Adam Johnson - 回复
I like it. The link for the screen is dead for me but I will find one.
Spencer Saunders - 回复
Thanks for this. Just repaired 3 laptops for my classroom! Super easy.
Andrew Davis - 回复
浏览统计数据:
过去的24小时: 5
过去的7天: 50
过去的30天: 213
总计 37,029
