简介
If you experiencing problems listed in the troubleshooting guide, you can replace the hard drive. The hard drive stores the operating system (Chrome OS), along with saved files and pictures. Installing a new hard drive will require reinstalling Chrome OS and backing up your local files.
你所需要的
Place the laptop on a flat surface with the bottom side facing up.
Place the tip of a spudger or finger into the hole on the battery release slider.
Use the screwdriver to pierce the warranty sticker.
Unscrew and remove the #0 6mm Phillips screw and set it aside.
21等其他人完成本指南。
8条评论
Attempted to upgrade my C710 with the:
PNY XLR8 SATA 120GB 6Gbps 2.5-Inch Solid State Drive SSD9SC120GMDF-RB
Didn't fit.
Unfortunately, one corner of the SSD --near the SATA-connector-- interferes with a screw on the motherboard/chassis. And then the laptop cover cannot be re-attached.
Hope this comment saves someone some grief.
Not sure I understand.
Pics?
When Ze -
Seems its still not clear what brand/size of SSD that you can upgrade to? 60GB? 120? 480?
When Ze -
Bootable flash drive did not get the C710 working until I reseated the HDD. Never would have known about the hidden screw unless I read this,
-rko
Unit requesting recovery even after carrying out the listed procedure,tried to upgrade to a 128 ssd but won,t, reinstalled hhd after viewing folders on another computer and the unit finally booted again into chrome screen. Would still like to install ssd drive
