跳转到主内容
Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement
你所需要的
  1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 步骤 2 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 步骤 2 中的图像 2,2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 步骤 3 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 步骤 4 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 步骤 4 中的图像 2,2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: 步骤 5 中的图像 1,3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: 步骤 5 中的图像 2,3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: 步骤 5 中的图像 3,3
    • The Solid State Drive is the blue chip locate right beneath the fan.
    • Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
  6. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 步骤 6 中的图像 1,2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 步骤 6 中的图像 2,2
    • Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
结论
5等其他人完成本指南。
Sakiynah Howard
于10/17/17注册
1,000 声望
创作了6篇指南
团队
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G3
3 名成员
创作了12篇指南
一条评论
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
Helios Bajammin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 39
总计 3,285
