简介
This guide will walk you through the process of replacing a dead or dying battery in the Acer Chromebook 15 CB5-571-C09S.
你所需要的
Place the device on a flat surface faced down so that the fan vents are at the top of the device.
Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
8等其他人完成本指南。
2条评论
Where do you get the plastic opening tools
Instructions were perfect. Used a putty knife to pry off the back
