跳转到主内容
Acer Chromebook 14 CB3-431-C7EX Speakers Replacement
你所需要的
  1. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement, Speakers: 步骤 1 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement, Speakers: 步骤 1 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement, Speakers: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws and then remove the cover.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 步骤 2 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 步骤 2 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 步骤 3 中的图像 1,2 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the battery housing.
  4. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 步骤 4 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 步骤 4 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 步骤 4 中的图像 3,3
    • Lift the left and right speakers directly upward from the laptop to remove them.
    • Unwind the wire connecting the two speakers from the slalom.
    • The connection between the wire and the speakers may be fragile.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 340
