跳转到主内容
Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement
你所需要的
  1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 步骤 2 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 步骤 2 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 步骤 3 中的图像 1,2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to carefully disconnect the ribbon connector from the right side of the sound card. The connector should slide out toward the motherboard.
    • Be sure to remove the connector evenly from the port, as the ribbon connector may be fragile.
  4. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 步骤 4 中的图像 1,2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
  5. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Slide the sound card towards the motherboard until the headphone jack is out of its hole on the side of the laptop.
    • Lift the sound card directly up from the laptop to remove it.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 605
