跳转到主内容
Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement
你所需要的
  1. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 2 中的图像 1,2 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the screen brackets.
    • Use tweezers to set aside the ground tape (tan) and the electrical tape (black). This may need to be reconnected during reassembly.
  3. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 3 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 3 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 3 中的图像 3,3
    • Use tweezers to detach the webcam connectors from the motherboard.
    • Keep in mind that the black cable connects to the left pin and the white cable connects to the right pin.
    • There may be electric tape covering the connectors. Use tweezers to set aside the tape for reuse.
  4. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 4 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 4 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Disconnect the display panel connector from the motherboard. The connector should slide out away from the motherboard.
    • Be sure to remove the connector evenly from the port.
  5. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 5 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 5 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 步骤 5 中的图像 3,3
    • To remove the lid from the laptop, pivot each end on the hinge and lift the rest of the laptop up and away from the lid.
    • Remove the display assembly from the laptop case.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 808
