跳转到主内容
Acer Chromebook 14 CB3-431-C7EX Battery Replacement
你所需要的
  1. Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: 步骤 1 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: 步骤 1 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • There are several clips holding the cover in place.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 步骤 2 中的图像 1,3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 步骤 2 中的图像 2,3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to disconnect the battery's connector from the motherboard. The connector should slide out toward the battery.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 步骤 3 中的图像 1,2 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver to unscrew the two 5.5mm screws from the battery housing.
  4. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 步骤 4 中的图像 1,1
    • While lifting the connector side of the battery, slide the battery towards the center of the laptop.
    • Be mindful of the tabs on the bottom of the battery housing (shown in picture). These need to be underneath slots when reinserting the battery back into the laptop.
    • Remove the battery from the laptop.
结论
3等其他人完成本指南。
一条评论
clear and concise
good instructions
battery can be found for less than half that cost online
mapatouli - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 52
总计 1,767
