跳转到主内容
Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement
你所需要的
  1. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: 步骤 3 中的图像 1,2 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: 步骤 3 中的图像 2,2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: 步骤 4 中的图像 1,1
    • Lift off the back cover.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 683
