跳转到主内容
Acer Chromebook 13 CB5-311-T7NN Battery Replacement
你所需要的
  1. Acer Chromebook 13 CB5-311-T7NN Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the computer over and use a Phillips #0 screwdriver head to remove the 13 2.5 mm bottom cover screws.
  2. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: 步骤 2 中的图像 1,1
    • Use your spudger to carefully pry the bottom cover away from the palm rest assembly.
    • Don't pull the cover away too hard once it's apart from the assembly because the headphone jack cable is still attached to the bottom cover.
  3. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: 步骤 3 中的图像 1,1
    • Use the pointed side of the spudger to disconnect the headphone jack cable from the motherboard and completely remove the bottom cover.
  4. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: 步骤 4 中的图像 1,1
    • Use the pointed side of the spudger to disconnect the battery cable from the motherboard.
  5. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: 步骤 5 中的图像 1,2 Acer Chromebook 13 CB5-311-T7NN Battery Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #0 screwdriver head to remove the two 2.5 mm #1 battery screws.
    • Use your hands to remove the battery by gently picking it up.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 1,443
