跳转到主内容
Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement
你所需要的
  1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: 步骤 1 中的图像 1,2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: 步骤 1 中的图像 2,2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: 步骤 3 中的图像 1,2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 步骤 4 中的图像 1,2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 步骤 4 中的图像 2,2
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 步骤 5 中的图像 1,1
    • Remove the battery.
  6. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: 步骤 6 中的图像 1,2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: 步骤 6 中的图像 2,2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 步骤 7 中的图像 1,3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 步骤 7 中的图像 2,3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 步骤 7 中的图像 3,3
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
结论
团队
USF Tampa, Team S15-G4, Boczar Spring 2018 USF Tampa, Team S15-G4, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 178
