简介
Do not proceed with this guide unless you are prepared to clean and re-apply thermal compound. For more information, please refer to the How to Clean and Apply Thermal Compound guide.
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
Using the plastic tabs, lift the hard drive slightly and pull to the left.
Remove the rubber mounting brackets from the hard drive.
Locate the memory modules at the bottom right quadrant of the motherboard. The two memory modules are slightly stacked on top of each other.
Using both hands, pull the clasps away simultaneously in order to release the memory modules.
Locate the wireless card on the top left quadrant. It should have two antenna cables connected to it, one white and one black.
Use a Phillips Head size #1 screwdriver to remove the two silver-colored 10mm Phillips Head screws securing the fan to the motherboard.
With all major components removed, proceed to locate the connectors marked on the photograph:
Power jack harness connector.
Ribbon cables.
Display cable connector.
Keyboard connector.
You can follow the steps in reverse to reassemble your device, but you should not re-seat the heat sink and fan without cleaning and re-applying the thermal compound.
2等其他人完成本指南。
2条评论
Is it necessary to remove everything especially heat sink if I want to replace only keyboard?
