跳转到主内容
Acer Aspire V5-591G-75KE Hard Drive Replacement
你所需要的
  1. Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: 步骤 1 中的图像 1,3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: 步骤 1 中的图像 2,3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: 步骤 1 中的图像 3,3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Hard Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire V5-591G-75KE Hard Drive Replacement: 步骤 2 中的图像 2,2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Hard Drive Replacement: 步骤 3 中的图像 1,2 Acer Aspire V5-591G-75KE Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Hard Drive Replacement: 步骤 4 中的图像 1,3 Acer Aspire V5-591G-75KE Hard Drive Replacement: 步骤 4 中的图像 2,3 Acer Aspire V5-591G-75KE Hard Drive Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,3 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • Using the plastic tabs, lift the hard drive slightly and pull to the left.
    • Remove the rubber mounting brackets from the hard drive.
    • If you are replacing your hard drive with a new one, please note you will need to reuse the rubber mounting brackets in order to secure it in place.
结论
另外一个人完成了本指南。
Reina Godeck
于10/16/17注册
741 声望
创作了5篇指南
团队
UW Tacoma, Team S3-G5, Liner Fall 2017 UW Tacoma, Team S3-G5, Liner Fall 2017 的会员
UWT-LINER-F17S3G5
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 1,132
