跳转到主内容
Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade
你所需要的
视频概述
  1. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Bottom Cover: 步骤 1 中的图像 1,1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 步骤 2 中的图像 1,1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 步骤 3 中的图像 1,3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 步骤 3 中的图像 2,3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 步骤 3 中的图像 3,3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 步骤 4 中的图像 1,1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): 步骤 5 中的图像 1,3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): 步骤 5 中的图像 2,3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): 步骤 5 中的图像 3,3
    • This model have 1x Memory Slot.
    • You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
结论
6等其他人完成本指南。
ZFix
于12/09/13注册
191,203 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,523篇指南
一条评论
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 71
总计 22,725
