当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Use plastic tools to avoid damaging the cover.
Remove the bottom case.
Disconnect the Fan cable.
Remove the three screws from the CPU cooler and one from the Fan module.
When you change the Cooling system, you must clean the processor from old thermal compound and put new.
Use a lint-free cloth to clean the old thermal compound.
If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
Use again cloth with isopropyl alcohol to clean the Thermal surface.
Use the same technic to clean the surface of the processor from the old thermal compound
Be carefully,if you don't want to break the CPU.
Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
