跳转到主内容
Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement
你所需要的
视频概述
  1. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 2 中的图像 1,1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 3 中的图像 1,3 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 3 中的图像 2,3 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 3 中的图像 3,3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Cooling / Fan System: 步骤 5 中的图像 1,2 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Cooling / Fan System: 步骤 5 中的图像 2,2
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
  6. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 6 中的图像 1,3 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 6 中的图像 2,3 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 6 中的图像 3,3
    • Use a lint-free cloth to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Use again cloth with isopropyl alcohol to clean the Thermal surface.
  7. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 7 中的图像 1,3 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 7 中的图像 2,3 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 7 中的图像 3,3
    • Remove the 3x Phillips screws and open the Fan case.
    • Use a soft brush and clean the Fan and the Cooler.
  8. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 8 中的图像 1,3 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 8 中的图像 2,3 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 8 中的图像 3,3
    • Use the same technic to clean the surface of the processor from the old thermal compound
    • Be carefully,if you don't want to break the CPU.
    • Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
  9. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 9 中的图像 1,2 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 步骤 9 中的图像 2,2
    • Careful install the Cooling system with even pressure from all sides, and the bead that you placed on the surface will spread over the entire contact surface.
结论
ZFix
于12/09/13注册
191,278 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 18
总计 3,160
