跳转到主内容
Acer Aspire V5-572 Bottom Cover Replacement
你所需要的
视频概述
  1. Acer Aspire V5-572 Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 Bottom Cover Replacement: 步骤 2 中的图像 1,1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 Bottom Cover Replacement: 步骤 3 中的图像 1,3 Acer Aspire V5-572 Bottom Cover Replacement: 步骤 3 中的图像 2,3 Acer Aspire V5-572 Bottom Cover Replacement: 步骤 3 中的图像 3,3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572 Bottom Cover Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
结论
另外一个人完成了本指南。
ZFix
于12/09/13注册
192,056 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
一条评论
Hello, I'm just trying to find this bottom casing -- anywhere -- and cannot seem to be able to find or purchase one. Often the wrong one comes up when I search (as evidenced by vents in the wrong places). Any ideas? Thanks in advance.
bellemcc - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 21
总计 3,915
