跳转到主内容
Acer Aspire V5-571-6891 Keyboard Replacement
你所需要的
  1. Acer Aspire V5-571-6891 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
  2. Acer Aspire V5-571-6891 Keyboard Replacement: 步骤 2 中的图像 1,2 Acer Aspire V5-571-6891 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the battery out of the battery slot.
  3. Acer Aspire V5-571-6891 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the two 6mm PH1 screws from the bottom of the laptop.
  4. Acer Aspire V5-571-6891 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
    • Do this with the computer slightly open for ease.
  5. Acer Aspire V5-571-6891 Keyboard Replacement: 步骤 5 中的图像 1,2 Acer Aspire V5-571-6891 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Open the laptop.
    • Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
    • The keyboard can be flipped onto its face once removed.
  6. Acer Aspire V5-571-6891 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
  7. Acer Aspire V5-571-6891 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the keyboard by pulling the blue tape on the wire strip.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 693
