跳转到主内容
Acer Aspire V5-571-6889 Hard Drive Replacement
你所需要的
  1. Acer Aspire V5-571-6889 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Hard Drive Replacement, Remove Upper Cover: 步骤 5 中的图像 1,1
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 657
