简介
How to disassemble the laptop, clean or replace the Cooling system or the Fan and change CPU Thermal Compound / Grease. This will help you if your system overheads or switch off randomly.
____________________________________________________________________________
你所需要的
视频概述
Turn off the laptop and remove the battery.
Remove two screws securing the Keyboard.
The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
Remove the Keyboard and disconnect the two flex cables:
Keyboard flex cable
Keyboard Light flex cable
Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
Slide the drive to the left and remove it.
Remove 4x phillips screws and disconnect:
Power On button flex cable
Touch pad flex cable
Remove 18x Phillips screws from the bottom cover.
Remove any memory SD Card from the Card reader.
Start opening with a plastic opening tool.
After removing the 18x Phillips screws, the laptop is VERY fragile in the hinge area. The bottom cover will easily crack or break in the hinge area when opening the laptop with no screws, particularly the left side near the power button. Possibly this step should be revised to recommend opening the laptop 90 degrees before removing the 18x screws. Or, advise extreme caution when opening the laptop with no screws.
jonnyquest - 回复
Hi, do you know where buy screws that you mention in step 4? “Remove 18x Phillips screws from the bottom cover.”
I am italian. Thank you anyway.
The laptop I have included 6x screws from inside and 16x screws from the bottom. This seems to be a minor variation from model to model.
Gently remove the HDD and disconnect the SATA cable from it.
Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
Remove the Wi-Fi card.
Disconnect the Fan cable.
Unscrew the screws that hold the Cooling system to the Mother board.
Carefully lift the Cooling system right up.
4等其他人完成本指南。
一条评论
Hello!
Is ist possible to installa SSD storage to the V5-571G without removing the SATA?
Thanks for your reply
The two clips push toward the space-bar part of the keyboard. There are further clips around the edge of the keyboard, but it can be removed by careful prying with a thin blade screwdriver.
ENT - 回复
