跳转到主内容
Acer Aspire V5-571 CMOS / Bios Battery Replacement
你所需要的
视频概述
  1. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Keyboard: 步骤 1 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, Keyboard: 步骤 1 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 2 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 2 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 2 中的图像 3,3
  3. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Optical Drive: 步骤 3 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, Optical Drive: 步骤 3 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, Optical Drive: 步骤 3 中的图像 3,3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Upper  Cover: 步骤 4 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, Upper  Cover: 步骤 4 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, Upper  Cover: 步骤 4 中的图像 3,3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 5 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 5 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 5 中的图像 3,3
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 CMOS / Bios Battery Replacement, HDD (Hard Disk Drive): 步骤 6 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, HDD (Hard Disk Drive): 步骤 6 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, HDD (Hard Disk Drive): 步骤 6 中的图像 3,3
  7. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Wi-Fi Half Mini PCIe card: 步骤 7 中的图像 1,2 Acer Aspire V5-571 CMOS / Bios Battery Replacement, Wi-Fi Half Mini PCIe card: 步骤 7 中的图像 2,2
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Mother Board: 步骤 8 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, Mother Board: 步骤 8 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, Mother Board: 步骤 8 中的图像 3,3
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 9 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 9 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 9 中的图像 3,3
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 10 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 10 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement: 步骤 10 中的图像 3,3
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 CMOS / Bios Battery Replacement, CMOS / BIOS Battery: 步骤 11 中的图像 1,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, CMOS / BIOS Battery: 步骤 11 中的图像 2,3 Acer Aspire V5-571 CMOS / Bios Battery Replacement, CMOS / BIOS Battery: 步骤 11 中的图像 3,3
    • Use sharp plastic tool and remove the CMOS Battery.
    • CR2032 - button cell lithium battery rated at 3.0 volts.
    • Did you do it successfully?
结论
7等其他人完成本指南。
ZFix
于12/09/13注册
191,308 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
7条评论
I need assistance with the G2201 Hardware Gap, Im attempting to remove a HHD password for a customers machine on this same model
chemanemelton - 回复
I have same problem with same mother board please help me
Mohammad Osman -
Hi. Thanks a lot. I manage to remove the CMOS battery, and I kept the laptop pc idle without the battery for nearly 7hrs. But still, when connected, I am asked for password/unlock key. Could you please help me how to discharge the CMOS.
amantaj - 回复
Hi.
Thanks so much.
I manage to remove the CMOS battery, and I kept the laptop pc idle without the battery for nearly 3hrs.
Omit Z - 回复
Please help me.
Omit Z - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 28
过去 30 天: 157
总计 33,604
