跳转到主内容
Acer Aspire V5-552PG-X469 Key Replacement
你所需要的
  1. Acer Aspire V5-552PG-X469 Key Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Place the end of a plastic opening tool underneath the edge of the broken key.
    • Gently pry up on the key until it comes loose.
    • Pry carefully to make sure you do not damage any of the internal hardware while removing the keys.
  2. Acer Aspire V5-552PG-X469 Key Replacement: 步骤 2 中的图像 1,1
    • Pick up the key to remove it.
    • If any debris is found underneath the key, clean it out with an air canister or cotton swab.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 858
