跳转到主内容
Acer Aspire V5-473P-5602 Motherboard Replacement
你所需要的
  1. Acer Aspire V5-473P-5602 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer Aspire V5-473P-5602 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Motherboard Replacement, Battery: 步骤 2 中的图像 1,2 Acer Aspire V5-473P-5602 Motherboard Replacement, Battery: 步骤 2 中的图像 2,2
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Motherboard Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Remove the four Phillips #0 screws from the hard drive.
  6. Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Gently unplug the hard drive connector.
  7. Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the hard drive from the laptop.
  8. Acer Aspire V5-473P-5602 Motherboard Replacement, Fan: 步骤 8 中的图像 1,2 Acer Aspire V5-473P-5602 Motherboard Replacement, Fan: 步骤 8 中的图像 2,2
    • Remove the five Phillips #0 screws that are holding the fan down to the base.
  9. Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 9 中的图像 1,2 Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Gently unplug the cables from the Wi-Fi card.
  10. Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the fan from the laptop.
  11. Acer Aspire V5-473P-5602 Motherboard Replacement, Secondary Cooling Fan: 步骤 11 中的图像 1,2 Acer Aspire V5-473P-5602 Motherboard Replacement, Secondary Cooling Fan: 步骤 11 中的图像 2,2
    • Unplug the cable that connects to the fan to motherboard.
  12. Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the two Phillips #0 screws that secure the fan to the base.
  13. Acer Aspire V5-473P-5602 Motherboard Replacement, Motherboard: 步骤 13 中的图像 1,2 Acer Aspire V5-473P-5602 Motherboard Replacement, Motherboard: 步骤 13 中的图像 2,2
    • Remove the ten Phillips #0 screws that attach the motherboard to the keyboard.
  14. Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 14 中的图像 1,3 Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 14 中的图像 2,3 Acer Aspire V5-473P-5602 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Unplug the two data cables that attach the keyboard to the motherboard.
    • Remove the motherboard from the laptop.
结论
另外一个人完成了本指南。
Kristen Gismondi
于11/12/14注册
82,570 声望
创作了201篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,410篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 33
总计 862
