跳转到主内容
Acer Aspire V5-131-2680 Screen Replacement
你所需要的
  1. Acer Aspire V5-131-2680 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Open up your laptop.
    • Place an opening tool in the crack between the screen and the back compartment. Drag the opening tool throughout the crack to open.
    • Remove the front black frame of the laptop.
  2. Acer Aspire V5-131-2680 Screen Replacement: 步骤 2 中的图像 1,1
    • Use a JIS #1 screwdriver to remove the 10 marked M2 x 3 Phillips screws.
    • Use a magnetic bit to fully remove the screws from their locations.
  3. Acer Aspire V5-131-2680 Screen Replacement: 步骤 3 中的图像 1,1
    • Remove then aluminum frame holding the screen in place.
    • This frame may have some sharp edges. Lift and remove slowly.
  4. Acer Aspire V5-131-2680 Screen Replacement: 步骤 4 中的图像 1,1
    • Carefully peel off the tape surrounding the screen.
  5. Acer Aspire V5-131-2680 Screen Replacement: 步骤 5 中的图像 1,1
    • Unplug the pin conector from the display.
    • This is a sensitive piece. Do not grab harshly or the pin can break.
    • The screen is now free to be removed.
结论
Mauricio Moreno
于09/26/22注册
601 声望
创作了5篇指南
团队
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S6G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 124
