跳转到主内容
Acer Aspire V5-131-2680 Hard Drive Replacement
  1. Acer Aspire V5-131-2680 Hard Drive Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Hard Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire V5-131-2680 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • On the sides of the hard drive, you will see two side tabs. This is what holds the hard drive in place.
    • Place your finger on the left tab and press on it to loosen the hard drive.
    • After the hard drive is loose, slide it out of the compartment.
    • Do not remove your finger from the side tab while removing the hard drive.
  4. Acer Aspire V5-131-2680 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • You have successfully removed the hard drive from the laptop.
结论
Mauricio Moreno
于09/26/22注册
601 声望
创作了5篇指南
团队
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S6G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 188
